- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to draw some lines on Inventor on an assembly, for use then on Simulation Mechanical like Beam elements. If I draw them via 2D Sketches, when I import the geometry to Simulation Mechanical, those lines doesn’t appear. I draw them on Inventor via 3D Sketches, and when I import the geometry to Simulation Mechanical, I say "YES" when it asks if I want to import 3D sketches. I can give them Beam element type, but when I want to setup the element definition, an error message appears (I enclose a picture with the error). Which will be the better way to draw these beam elements? I think drawing them directly with the draw feature of Simulation Mechanical is a little bit complicated (because you don’t have reference points for draw them easily).
Thank you for your answers,
Best regards,
Ibon Ruiz de Alda
