Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
683 Views, 5 Replies
Divergence error
How do I prevent a divergence error? I check the meshing size and made sure the bc was not too complex. I still get diveregence error. What to do?
5 REPLIES 5
Joey.X
Could you make it clear divergence in which analysis type? Since you asked question in fluid analysis, the divergence usually comes from (top are more common)
- Improper/illegal boundary conditions
- Over-constrained boundary conditions
- Poor mesh quality
- Too large time steps for unsteady analysis
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
I am doing steady fluid analysis. I uploaded the model as reactor 7 in dropbox. Can you see if I made a mistake.
Joey.X
hi, Asif,
I tried your most recent model reactor7.fem from dropbox, I put the fluid material to Air and turned on "turbulence" from setup/parameter/load curve tab/turbulence (change from 0 to 1). It solves, refer to attached images.
If the flow is turbulence flow (user needs to estimate the Reynolds number) , the turbulence has to be turned on , otherwise it may introduce the solution stability issue.
PS, I have uploaded the modified model (with results) into your dropbox.
Jianhui Xie, Ph.D
Principal Engineer
Hi Joey
I tried doing the analysis my self because I uploaded the model you saved from my dropbox but the results did not saved. I change the turbulence number to one. However, I still get a divergence error. How do you put the fluid material to air?
Joey.X
From FEA Editor/design scenario i/tree view/Parts/Part i/Material, right click to assign material/Edit material,
you can select material from material library /or edit existed material properties.If you see any RED cross, that indicates the model is not ready (incomplete).
I have uploaded the .zip file to your drop box, you can simply download/unzip it, and click .fem file to open the model in SIM/MP software, I have finished run for this model and the settings/results are complete.
Jianhui Xie, Ph.D
Principal Engineer
