I upgraded to 2017 and now I cannot archive my models.
After I select create archive I receive the error message "Failed to load control 'XceedZip' from XceedZip.dll. Your verison of XceedZip.dll may be outdated. Make sure you are using the version of the control that was provided with your application."
Then it tells me that it "Failed to create archive of the model'.
How can I resolve this?
Michael
Solved by mschroepfer. Go to Solution.
Hi Michael,
Sorry to hear about the archive problem. I could not find any information on this particular error, so you are entering new territory.
Have you tried to reboot your computer or restarting Sim Mech? I am wondering if it is a "random" glitch. Otherwise, try these items to see if it clears up the problem:
Regall.bat
Sim Mech as Administrator
If regall.bat does not solve the problem, then try this:
If those do not fix the problem, then please let us know the following:
In the meantime, you can use Windows compression utility or any other compression utility to zip the model (the .fem file) and the folder "modelname.ds_data". (The archive, the .ACH file, is a .zip format, so utilities that can read or create .zip files can view and extract .ACH files.)
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi @mschroepfer
Just wanted to see if you were able to try the ideas that I suggested.
Another thought that just came to mind is that perhaps the installation was not completely successful, or maybe something else got installed later that caused a conflict with the Xceed dll. (Let's blame a Windows update ). So if the previous suggestions do not fix the problem, the next test would be to uninstall and re-install the 2017 software.
I ran the regall.bat file. The black command prompt window never disappeared.
I tried running the Simulation as an administrator but that did not work either.
I am using Windows 7.
I am using 2017.01.01.3184 of Simulation.
I also uninstalled and reinstalled the software and that did not help either.
What should I do next?
Thanks.
Running the Regall.bat file must be done in a special way on Windows VISTA and 7:
cd "C:\Program Files\Autodesk\Simulation 2017\"
Then choose the <Enter> key on the keyboard.
"C:\Program Files\Autodesk\Simulation 2017\regall.bat"
This action will allow the batch file to run in the Simulation installation directory instead of the system32 directory and will finish in about 1 minute.
