Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Contour plot Simulation Mechanical 2017
1 REPLY 1
sunarjo
430 Views, 1 Reply
Dear Sir/ Madam,
I had a problem to show the result for contour plot. the model and contour plot show in white color.
I already tried set to default several option but, didn't work.
If, I save picture from ribbon option on top right, it ok
please see attachments.
thank you
regards
Sunarjo Leman
1 REPLY 1
John_Holtz
in reply to: sunarjo
Hi Sunarjo,
Please see this article: How to fix results contours not appearing in Simulation Mechanical
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
