Is there a way to fix this or force this situation to work as desired? Parts are to be meshed as layers of thin elements. Assembly is mostly welded but there are some welded sub-assemblies that are bolted to other parts or welded sub-assemblies. I cannot get the surface meshes on most of the solid-meshed parts to match up with the head & nut spokes of the bolt meshes.
Solved by John_Holtz. Go to Solution.
I may have my own answer now. I selected the construction vertices at the ends of the radial bolt spokes and used them to create refinement points. I set the refinement radius to just less than the thickness of the part and I set the mesh size to the thickness of the part (which was smaller than the existing mesh size prior to refinement, so maybe the key there is to just ensure that you're refining smaller than what you have currently, which is really the obvious intent anyway with refinement).
I then remeshed the entire assembly and the spokes are now properly matched with the surface nodes.
If there are other ways or if this approach has pitfalls I haven't found yet, please reply. Otherwise, I'll move on and will update this thread if needed.
UPDATE
Above approach does not work all the time. Still searching for solution.
Hi Bryan,
The reason that it does not work is because of the way the layered thin solid mesh works. It meshes the surface of the solid, takes one of the faces and deletes the other faces, and extrudes the face to create the solid. (The actual details may be a little different, but that is the general principle.)
So if the construction vertices created for the bolt are not on the side that gets extruded, the mesh between the bolt and solid will not match up. Here are some random ideas. (I have not tried any of these, so you might want to try a subset of your full model or create a small test model.)
Thanks John. I will try all three ideas to see what I like best. Your third option may be the best all-round since the CAD I get usually has flat washers anyway. Instead of suppressing them and placing bolts without washers, I could leave them and add the bolts as you suggest. My reluctance had been the small mesh of such washers driving mesh/solve times but we'll see. I'll bet they don't hurt much, especially since I don't care about the mesh/stress in the washers (they can be quite coarse I bet).
