Autodesk Simulation
Autodesk Simulation
BSer
Autodesk Simulation
BSer
I have a problem with the opening of the model to Autodesk Simulation. Error: The DLL "AlgConfig-win-x64.dll" was not able to be located for loading on behalf of "C:\Program Files\Autodesk\Simulation 2014\CImpAlnv-win-x64.dll". Contact technical support. Reinstalling the program has not solved the problem. Help please.
Andrew.Sartorelli
Hi BSer,
Welcome to the Simulation Mechanical forum. It sounds like your environment variables may not have been set up correctly during the installation process. Please try the following:
Verify the windows environment variables are properly set for the simulation mechanical installation. Update if necessary.
For Simulation Mechanical 2015 a variable named ALGOR_ROOT_2015 should be present. The variable value should point to the installation location similar to this.
C:\Program Files\Autodesk\Simulation 2015\
The process is similar for Simulation Mechanical 2014.
Andrew Sartorelli - Autodesk GmbH
BSer
Updating of the program also didn't solve a problem 😞
Andrew.Sartorelli
Hi BSer,
Try the following:
Open the command prompt as Administrator
Type: cd "C:\program files\autodesk\simulation 2015\" enter
Type: regall.bat
Wait for the process to finish
Open Simulation Mechanical
BSer
Я начал файла regall.bat  из каталога: "C: \ Program Files \ Autodesk \ моделирование 201 4 \ " . Система написал вам смотреть картину. Программа Autodesk Simulation также не сработал модель.
Andrew.Sartorelli
Hi BSer,
Are you running Windows 8.1? Simulation Mechanical 2014 only supports up to Windows 8.0, behavior in Windows 8.1 with Simulation Mechanical 2014 has been reported to be erratic and it is not advised that you use both together.
