Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Analysis goes to "Scheduled" status when launched, and stays that way.
5 REPLIES 5
Madjerry
1031 Views, 5 Replies
Whenever I "Run Simulation", the job goes to a "Scheduled" status, but never runs. I look at the details in Job Manager, and it says it is scheduled for the moment I launched it.
This is part of mass deployed image, so it may have something to do with that? I have tried reinstalling but it did not help.
When I shut down windows, Job Manager holds it open saying that it is still trying to submit jobs to the server.
Help?
5 REPLIES 5
Hi MadJerry,
Can you go into the task manager and look for a service called Mechanical Job Server. Once you find that service, start and restart it and that should kick the job through.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
Nope. Its not the same as the "stuck in queued status" issue. I have tried
restarting the service. I have reinstalled Sim Mech and Job Manager. It
didn't help. I can cancel the jobs and resend them, but they go right to
"Scheduled", not "Queued".
Hi Jerry,
Can you try deleting "C:\Users\%USERNAME%\AppData\Local\Autodesk\Mechanical Simulation Job Manager" and "C:\Users\%USERNAME%\AppData\Local\Autodesk\Web Services"? You will need to have Simulation Mechanical and the Simulation Job Manager closed when doing this. To close the SJM, right-click on it's icon in the system tray (the white arrow next to the clock) and select exit.
That did it. Thanks.
bryan_mcnatt
in reply to: Madjerry
Update ... This happened to me just now under version 2017.  The solution offered here worked, mostly.  I couldn't delete the Webservices folder entirely.  I tried in vain to find the process or service that was hanging on to some files there.  So, I deleted what I could and restarted.  All is well again.  For now. 🙂
Bryan McNatt, P.E.
MRD Engineering
www.mrd-engineering.com
