Whenever I "Run Simulation", the job goes to a "Scheduled" status, but never runs. I look at the details in Job Manager, and it says it is scheduled for the moment I launched it.
This is part of mass deployed image, so it may have something to do with that? I have tried reinstalling but it did not help.
When I shut down windows, Job Manager holds it open saying that it is still trying to submit jobs to the server.
Help?
Solved by Andrew.Sartorelli. Go to Solution.
Hi MadJerry,
Can you go into the task manager and look for a service called Mechanical Job Server. Once you find that service, start and restart it and that should kick the job through.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Jerry,
Can you try deleting "C:\Users\%USERNAME%\AppData\Local\Autodesk\Mechanical Simulation Job Manager" and "C:\Users\%USERNAME%\AppData\Local\Autodesk\Web Services"? You will need to have Simulation Mechanical and the Simulation Job Manager closed when doing this. To close the SJM, right-click on it's icon in the system tray (the white arrow next to the clock) and select exit.
Update ... This happened to me just now under version 2017. The solution offered here worked, mostly. I couldn't delete the Webservices folder entirely. I tried in vain to find the process or service that was hanging on to some files there. So, I deleted what I could and restarted. All is well again. For now. 🙂
