The "Autodesk_Simuation_Mechanical_2016_Multilingual_Win_64bit_dlm_001_002.sfx.exe" was available on our subscription page.
I downloaded the 2.0 gb install file. When I run it, it says "Product download consists of multiple files. At least one file is missing or has not been downloaded yet".
Only other files were the Valult file and the 12 mb install file that I assumed was used to download and install. We had wanted the 2.0 gb file for several installs.
What file is needed in order to extract the files??
Solved by david.lau. Go to Solution.
If you use IE, Chrome or Firefox, make sure that pop-up blockers are off.
This link will be valid for 7 days if you can't figure out the pop up settings;
Please provide me with the link of extra files for"Autodesk_Simuation_Mechanical_2016_Multilingual_Win_64bit_dlm_001_002.sfx.exe"
Hi, I'm also having the same issue. The popup blockers are stopping the other parts downloading.
I've tried doing a chat with tech support and it just says connecting. Is anyone able to post a current link to the missing files? Thanks for your help,
Ben
Hi Ben,
Sorry to hear about the problems with downloading the installation files. This method may work for you:
Does it download the two files?
If not, please confirm that you are trying to download version 2016.
Hi John, Thanks for your reply. I've tried your steps. Still have the same error occurring. It is the 2016 version that I'm trying. There is only one file that downloads. Autodesk_Simulation_Mechanical_2016_Multilingual_Win_64bit_dlm_001_002.sfx.exe
Hi @Anonymous
There are two versions of Sim Mech 2016:
The "Multi-lingual" version, which is what I think you have based on the link you show. The two download files are as follows:
and the "Flex" version (solves on the cloud). The two download files are as follows:
I hope these work
Thanks John, after using these files, and my internet at home, not my schools. I got It to work. The only problem I'm having now is licencing.
When I go to activate it has an error.
Thanks for initiating your product activation. The system encountered a problem registering or activating your product. Please submit your registration information to us in a Customer Service request and an Autodesk representative will contact you.
Any help is appreciated, Thanks John
The people on the Installation & Licensing forum should be able to help with activating the product.
