Dear All,
I'm a design student and I was trying to install "Showcase 2017" on my laptop but it doesn't want to install. (My operating system on my laptop is windows 10.)
I can download the "Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US_Setup_webinstall" and I also can run it. Then I move on to the installation of showcase. I choose which parts I want to install and choose my installation path, after that I click install. The installation starts and ends in 10 seconds. Then I get the window of installation complete, but as you can see nothing is installed with the note "some products failde to install".
(I added pictures below)
So I wonder what the problem is and what I can do about it to solve the problem to install "Showcase 2017".
Please let me know if you can relate to this problem or have a solution to this.
Thanks in advance,
Kind regards
Tim Bernaerts
it also says for more information view the install logs
did you view them? if so what does it say?
Below is the installation log.
I don't understand it so I hope you can help me.
2016/9/29:16:27:35 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:27:35 TB TB-MSI Path_Length: 158
2016/9/29:16:27:35 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:27:35 TB TB-MSI Launch
2016/9/29:16:27:35 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:27:35 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIC86A.tmp
2016/9/29:16:27:55 TB TB-MSI === Setup ended ===
2016/9/29:16:27:36 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:27:36 TB TB-MSI Path_Length: 158
2016/9/29:16:27:36 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIC86A.tmp
2016/9/29:16:27:36 TB TB-MSI Launch
2016/9/29:16:27:36 TB TB-MSI Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:27:36 TB TB-MSI Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:27:37 TB TB-MSI Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:27:55 TB TB-MSI Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:27:55 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:28:00 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:28:00 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:16:28:00 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:29:16 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:29:16 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:29:16 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:29:16 TB TB-MSI Download Play VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:29:18 TB TB-MSI Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:29:18 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:16:29:19 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:16:29:19 TB TB-MSI Download Play VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:29:21 TB TB-MSI Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:29:21 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:16:29:22 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:16:29:22 TB TB-MSI Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:29:26 TB TB-MSI Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:29:26 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:16:29:26 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:16:29:26 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:16:29:26 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/29:16:29:26 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:30:10 TB TB-MSI === Setup ended ===
2016/9/29:16:30:59 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:30:59 TB TB-MSI Path_Length: 158
2016/9/29:16:30:59 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:30:59 TB TB-MSI Launch
2016/9/29:16:30:59 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:30:59 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIE5F5.tmp
2016/9/29:16:31:01 TB TB-MSI === Setup ended ===
2016/9/29:16:31:00 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:31:00 TB TB-MSI Path_Length: 158
2016/9/29:16:31:00 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIE5F5.tmp
2016/9/29:16:31:00 TB TB-MSI Launch
2016/9/29:16:31:00 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:31:00 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:31:01 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:31:05 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:31:05 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:31:27 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:31:28 TB TB-MSI Installing Network License Manager: INSTALLDIR="D:\Program Files\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Showcase® 2017" SETUP_PACKAGECODE={7D9C65DF-45B2-461E-9EC9-5489D8AC313E} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/29:16:31:28 TB TB-MSI Install Network License Manager Succeeded
2016/9/29:16:31:28 TB TB-MSI Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SUCC...
2016/9/29:16:31:29 TB TB-MSI Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SUCC...
2016/9/29:16:31:29 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:31:31 TB TB-MSI === Setup ended ===
2016/9/29:16:32:14 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:32:14 TB TB-MSI Path_Length: 158
2016/9/29:16:32:14 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:32:14 TB TB-MSI Launch
2016/9/29:16:32:14 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:32:14 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AI9C5.tmp
2016/9/29:16:32:15 TB TB-MSI === Setup ended ===
2016/9/29:16:32:15 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:32:15 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:32:15 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:32:19 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:32:19 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:16:32:19 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:32:57 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:32:57 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:32:57 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:32:57 TB TB-MSI Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:32:57 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:16:32:58 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:16:32:58 TB TB-MSI Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:32:58 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:16:32:58 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:16:32:58 TB TB-MSI Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:32:58 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:16:32:58 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:16:32:59 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:16:32:59 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/29:16:32:59 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:33:03 TB TB-MSI === Setup ended ===
2016/9/29:16:33:12 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:33:12 TB TB-MSI Path_Length: 158
2016/9/29:16:33:12 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:33:12 TB TB-MSI Launch
2016/9/29:16:33:12 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:33:12 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIEBF7.tmp
2016/9/29:16:33:13 TB TB-MSI === Setup ended ===
2016/9/29:16:33:13 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:33:13 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:33:13 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:33:17 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:33:17 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:16:33:17 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:33:30 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:33:30 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:33:31 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:33:31 TB TB-MSI Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:33:31 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:16:33:31 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:16:33:31 TB TB-MSI Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:33:31 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:16:33:31 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:16:33:31 TB TB-MSI Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:33:31 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:16:33:32 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:16:33:32 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:16:33:32 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/29:16:33:32 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:33:35 TB TB-MSI === Setup ended ===
2016/9/29:16:34:29 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:34:29 TB TB-MSI Path_Length: 158
2016/9/29:16:34:29 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:34:29 TB TB-MSI Launch
2016/9/29:16:34:29 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:34:29 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AI1832.tmp
2016/9/29:16:34:30 TB TB-MSI === Setup ended ===
2016/9/29:16:34:30 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:34:30 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:34:30 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:34:34 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:34:34 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:16:34:34 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:34:49 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:34:49 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:34:49 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:34:50 TB TB-MSI Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:34:50 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:16:34:50 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:16:34:50 TB TB-MSI Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:34:50 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:16:34:50 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:16:34:50 TB TB-MSI Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:34:50 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:16:34:51 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:16:34:51 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:16:34:51 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/29:16:34:51 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:35:03 TB TB-MSI === Setup ended ===
2016/9/29:16:36:27 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:36:27 TB TB-MSI Path_Length: 158
2016/9/29:16:36:27 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:36:27 TB TB-MSI Launch
2016/9/29:16:36:27 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:36:27 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIE66A.tmp
2016/9/29:16:36:29 TB TB-MSI === Setup ended ===
2016/9/29:16:36:28 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:36:28 TB TB-MSI Path_Length: 158
2016/9/29:16:36:28 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIE66A.tmp
2016/9/29:16:36:28 TB TB-MSI Launch
2016/9/29:16:36:28 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:36:28 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:36:29 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:36:35 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:36:35 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:16:36:35 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:36:49 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:36:49 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:36:49 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:36:49 TB TB-MSI Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:36:49 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:16:36:50 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:16:36:50 TB TB-MSI Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:36:50 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:16:36:50 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:16:36:50 TB TB-MSI Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:36:50 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:16:36:51 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:16:36:51 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:16:36:51 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/29:16:36:51 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:36:59 TB TB-MSI === Setup ended ===
2016/9/29:16:47:53 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:16:47:53 TB TB-MSI Path_Length: 158
2016/9/29:16:47:53 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:16:47:53 TB TB-MSI Launch
2016/9/29:16:47:53 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:16:47:53 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AI5D7E.tmp
2016/9/29:16:47:54 TB TB-MSI === Setup ended ===
2016/9/29:16:47:54 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:47:54 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:16:47:54 TB TB-MSI PageOpen LaunchDialog
2016/9/29:16:48:41 TB TB-MSI PageOpen LicenseDialog
2016/9/29:16:48:41 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:16:48:41 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:16:51:26 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:16:51:26 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:51:26 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:16:51:27 TB TB-MSI Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:51:27 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:16:51:27 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:16:51:28 TB TB-MSI Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:51:28 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:16:51:28 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:16:51:28 TB TB-MSI Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:16:51:28 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:16:51:29 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:16:51:29 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:16:51:29 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/29:16:51:29 TB TB-MSI PageOpen InstallCompleteDialog
2016/9/29:16:54:07 TB TB-MSI === Setup ended ===
2016/9/29:19:13:28 TB TB-MSI === Setup started on TB-MSI by TB ===
2016/9/29:19:13:28 TB TB-MSI Path_Length: 158
2016/9/29:19:13:28 TB TB-MSI Current Directory C:\Autodesk\Autodesk_SC_2017_Multilingual_Win_64bit_wi_en-US
2016/9/29:19:13:28 TB TB-MSI Launch
2016/9/29:19:13:28 TB TB-MSI CommandLine /PK 262I1 /SN 900-32863776 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/Autodesk_SC_2017_Multilingual_Win_64bit_wi_..."
2016/9/29:19:13:28 TB TB-MSI Current Directory C:\Users\TB\AppData\Local\Temp\_AIA6F4.tmp
2016/9/29:19:13:30 TB TB-MSI === Setup ended ===
2016/9/29:19:13:29 TB TB-MSI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:19:13:29 TB TB-MSI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/SETU...
2016/9/29:19:13:30 TB TB-MSI PageOpen LaunchDialog
2016/9/29:19:14:29 TB TB-MSI PageOpen LicenseDialog
2016/9/29:19:14:29 TB TB-MSI PageOpen ProductInfoDialog
2016/9/29:19:14:29 TB TB-MSI PageOpen ProductSelectionDialog2
2016/9/29:19:14:39 TB TB-MSI PageOpen FullProgressDialog
2016/9/29:19:14:40 TB TB-MSI Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:19:14:41 TB TB-MSI Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/STAR...
2016/9/29:19:14:41 TB TB-MSI Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:19:14:41 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2012.log
2016/9/29:19:14:41 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/29:19:14:41 TB TB-MSI Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:19:14:41 TB TB-MSI Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x64_2012.log
2016/9/29:19:14:42 TB TB-MSI Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/29:19:14:42 TB TB-MSI Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/SHOWCASE/WI/{02D33709-CC52-4F5C-B792-079AF18DA8EE}/VCRE...
2016/9/29:19:14:42 TB TB-MSI Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\TB\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/29:19:14:42 TB TB-MSI Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Installation aborted, Result=1638
2016/9/29:19:14:42 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/9/29:19:14:42 TB TB-MSI Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
