Hi @Anonymous,
From the translation, I get: 'The main page keeps showing that your eligibility to use Autodesk products is being filtered by the standard output, and you cannot get the products
Why my education qualification has passed and I have received the email, but the main page keeps showing that your qualification for using Autodesk products is being filtered by the standard output, and I cannot get the products, how can I solve it?'
From this, it looks like you're going through Export Screening which is a separate process to educational access, most of the time will just clear on its own but you can reach out to support to chase it up if it doesn't clear in 48 hours. https://knowledge.autodesk.com/contact-support
As I said earlier it can take up to 48 hours.
How long had it been when you created this topic?
您好!
如果您已经获得教育版的授权但仍然无法激活软件,您需要联系我们的教育版客户支持,他们会在后台给您解决:https://www.autodesk.com.cn/education/support/edu-contact-us-form
