Screencast does not correctly record Showcase.
With AERO theme desactivated, Screencast does not start.
1. Launch sreencast
2. Launch Showcase
3. Recording...
4. Cry : https://screencast.autodesk.com/Main/Details/a239f751-6a20-4232-9110-ec58bda0f7c1
The Window is duplicated and scaled : the action shown is not under the cursor....
Cursor seems to be in the big window, freezed, in the background.
Visible action is in the foreground, in a scaled window.
Any fix ?
Solved by djovica30. Go to Solution.
Hi Idubail,
Is there a specific reason why you're deactivating AERO theme? Currently, the Screencast Recorder is able to record properly only when the Desktop Composition is enabled. We recommened users to switch to the Aero theme because that typically enables Desktop Composition.
Try recording a screencast with 'Desktop Composition' enabled. I'm hoping this will fix your issue.
Sree
Screencast QA Lead
Autodesk, Inc.
1 Market Street, Suite 200
San Francisco, CA 94105
Please use .Accept as Solution &Kudos to further enhance the value of these forums. Thank you!
Thank you for reply.
My problem is that when I start Showcase, the Windows Aero Theme is automatically desactivated.
Do you know if it's possible to start Showcase and keep in "Desktop composition" ?
(I'm not at the office this week...).
Thanks for the tip.
Even if, when Showcase is running, you re-activate Aero theme, Screencast make a bad recording.
No solution...
Do not use Screencast whith Autodesk Showcase, that's it ! ;o)
You can't have Showcase open when you start a recording. You need to start a recording, then launch Showase:
1. Start a screencast recording
2. Specify a region
3. Launch Showcase
4. Load the model
5. Do your thing!
6. Edit (Cut) the first part where Showcase is loading
Here's an example: http://autode.sk/1AJ0ieL
