The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Scaleform Forum (Read Only)
Scaleform enables developers to leverage the power of the Adobe® Flash® tool set to create powerful user interface environments for video games.
Scaleform 4.2.24 Android Emulator and device errors
4 REPLIES 4
wxneypar
1173 Views, 4 Replies
Hi everyone! I'm struggling to make my scaleform for Android to work.
I can build and install in device and in emulator from command line and via the deployer app.
Everything allright til here:
When I try to run depApp (just loads one of the sample swf's )in the emulator it simply crashes, maybe some misconfiguration in it:
03-21 16:25:08.020: I/ActivityManager(387): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.scaleform.depApp/.MainActivity} from pid 712
03-21 16:25:08.110: E/gralloc_goldfish(52): gralloc_alloc: Mismatched usage flags: 246 x 410, usage 333
03-21 16:25:08.110: W/GraphicBufferAllocator(52): alloc(246, 410, 1, 00000333, ...) failed -22 (Invalid argument)
03-21 16:25:08.110: E/(52): GraphicBufferAlloc::createGraphicBuffer(w=246, h=410) failed (Invalid argument), handle=0x0
03-21 16:25:08.120: E/BufferQueue(387): [ScreenshotClient] dequeueBuffer: SurfaceComposer::createGraphicBuffer failed
03-21 16:25:08.150: W/WindowManager(387): Screenshot failure taking screenshot for (246x410) to layer 21005
03-21 16:25:08.390: I/ActivityManager(387): Start proc com.scaleform.depApp for activity com.scaleform.depApp/.MainActivity: pid=1095 uid=10052 gids={50052, 3003}
03-21 16:25:09.180: D/dalvikvm(1095): Trying to load lib /data/app-lib/com.scaleform.depApp-1/libfmodex.so 0xb3d917e8
03-21 16:25:09.200: D/dalvikvm(1095): Added shared lib /data/app-lib/com.scaleform.depApp-1/libfmodex.so 0xb3d917e8
03-21 16:25:09.200: D/dalvikvm(1095): No JNI_OnLoad found in /data/app-lib/com.scaleform.depApp-1/libfmodex.so 0xb3d917e8, skipping init
03-21 16:25:09.210: D/dalvikvm(1095): Trying to load lib /data/app-lib/com.scaleform.depApp-1/libdepApp.so 0xb3d917e8
03-21 16:25:09.290: D/dalvikvm(1095): Added shared lib /data/app-lib/com.scaleform.depApp-1/libdepApp.so 0xb3d917e8
03-21 16:25:09.610: D/(1095): HostConnection::get() New Host Connection established 0xb71b4cb0, tid 1095
03-21 16:25:09.720: W/EGL_emulation(1095): eglSurfaceAttrib not implemented
03-21 16:25:09.740: D/OpenGLRenderer(1095): Enabling debug mode 0
03-21 16:25:09.850: D/(1095): HostConnection::get() New Host Connection established 0xb71b8a38, tid 1110
03-21 16:25:10.380: I/ActivityManager(387): Displayed com.scaleform.depApp/.MainActivity: +2s44ms
03-21 16:25:10.440: I/fmod(1095): FMOD: AudioDevice::run               : Min buffer size: 4456 bytes
03-21 16:25:10.440: I/fmod(1095): FMOD: AudioDevice::run               : Actual buffer size: 16384 bytes
03-21 16:25:11.220: D/MobileDataStateTracker(387): default: setPolicyDataEnable(enabled=true)
03-21 16:25:11.640: E/dalvikvm(1095): JNI ERROR (app bug): accessed stale local reference 0xb6b00025 (index 9 in a table of size 0)
03-21 16:25:11.650: W/dalvikvm(1095): JNI WARNING: jclass is an invalid local reference (0xb6b00025) (GetMethodID)
03-21 16:25:11.660: W/dalvikvm(1095):              in Ldalvik/system/NativeStart;.run:()V (GetMethodID)
03-21 16:25:11.660: I/dalvikvm(1095): "Thread-87" prio=5 tid=14 RUNNABLE
03-21 16:25:11.660: I/dalvikvm(1095):   | group="main" sCount=0 dsCount=0 obj=0xb3da42a0 self=0xb724ed28
03-21 16:25:11.670: I/dalvikvm(1095):   | sysTid=1108 nice=0 sched=0/0 cgrp=apps handle=-1223186584
03-21 16:25:11.670: I/dalvikvm(1095):   | state=R schedstat=( 250000000 600000000 58 ) utm=24 stm=1 core=0
03-21 16:25:11.670: I/dalvikvm(1095):   at dalvik.system.NativeStart.run(Native Method)
03-21 16:25:11.670: E/dalvikvm(1095): VM aborting
03-21 16:25:11.670: A/libc(1095): Fatal signal 6 (SIGABRT) at 0x00000447 (code=-6), thread 1108 (caleform.depApp)
03-21 16:25:12.190: I/DEBUG(50): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
03-21 16:25:12.190: I/DEBUG(50): Build fingerprint: 'generic/sdk/generic:4.4.2/KK/938007:eng/test-keys'
03-21 16:25:12.190: I/DEBUG(50): Revision: '0'
03-21 16:25:12.210: I/DEBUG(50): pid: 1095, tid: 1108, name: caleform.depApp  >>> com.scaleform.depApp <<<
03-21 16:25:12.210: I/DEBUG(50): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
BUT
When I run it in my device, a black screen appears reading "Failed to open the licence file. Please see the readme for licensing instructions, Error: 101", which is really weird because I have my sf_consumer_license_android_mobile.txt file with my licence in the bin folder, and I added it's path in the resources part of the app's .def file.
Am I missing something obvious? Why the errors and why diferent behaviours in emulator and device?
I would really appreciate your help, thanks in advance,
Pedro
PS: Scaleform 4.2.24 instalation, Android sdk level 19, ndk r8e on windows 7 64 bit OS
4 REPLIES 4
wxneypar
in reply to: wxneypar
Hi again, is anyone there? Am I asking in the wrong place?
Sorry for bothering you, but can someone help me here?
I have my perpetual licence and I can't make any demo or example to work!
Am I missing something? Is any newer version other than mine? (4.2.24). I read sth about 4.3 but can't find where to download it.
This is my .def file, I've added the path to my licence file as per the readme:
# This file defines an app based on FxShippingPlayer. The files that normally need to be changed
# will go in a directory named after this file in LocalApps. Each supported mobile platform will
# have its own icons and manifest. The Flash content and other resources are shared.
# Run make for the desired platforms once to setup the app.
# On Android, build the app by running make after making your changes.
# On iOS, an Xcode project will be created. Use this project to build and deploy the app; make does not
# actually build these apps.
# The display name of your app (visible to users)
DISPLAY_NAME := Dep App
# The package prefix. Often a reverse URL.
# If the package prefix is com.scaleform, then the
#  Android package will be:       com.scaleform.<APP_NAME>
#  Android main activity will be: com.scaleform.<APP_NAME>.MainActivity
PACKAGE := com.scaleform
# The Flash file to load at startup. This will be copied to flash.swf in this App's development
# directory (only during setup for iOS).
STARTUP_FLASH := Bin/Data/AS3/Samples/3DSquares.swf
# Other files needed by the app (extra swfs, image files, etc.)
# If the file list is too long for one line, you can put a backslash, followed immediately by a return (newline)
# List every individual file explicitly or include an entire directory by listing it with no trailing slash
# (See StarforceTD.def for an example of multiple files with directories)
RESOURCES := Bin/sf_consumer_license_android_mobile.txt
# List the orientations that the app will use. If only one is specified then the user cannot
# rotate the app. If none are specified then the behavior is arbitrary (normally based on sensor).
# If more than one is specified some platforms may allow any supported orientation, not just those in the list.
#ORIENTATIONS := portrait landscape reversePortrait reverseLandscape
# EdgeAA (0: off; 1: on)
EDGEAA := 1
# Online Game System (GameKit: Use Game Center; blank: Don't Use Game Center)
ONLINE_GAME_SYSTEM :=
# FMOD Sound support
USE_FMOD := 0
# Android Deployment
# Uncomment to automatically install on all connected devices (only when something was just built)
AUTODEPLOY := 1
# Uncomment to automatically launch the app after installing
AUTORUN := 1
 Thank you!
wxneypar
Hi, I got it running today, only on my device, but ONLY if my sf_consumer_license_android_mobile.txt is on the root of the sdcard.
If I remove I get the black screen reading: "Failed to open the license file. Please see the readme for licensing instructions. Error: 101"
Why is that happening if I have the file path included in my RESOURCES part of the .def???
This should be an easy question for you, could you please help me?
Thank you
nolver
Go to [scaleform_sdk_folder]/Src/Platform/Platform_Android.h
and look for "GFx_SetEvalKey"
Uncomment and put your license code there.
regards.
RichMC
Greetings, I have forwarded the post to development.
Richard Mc
Autodesk Gameware
Scaleform Division
