Hello:
Some of you might get a “dllnotfound” exception while running the HelloWorldDemo.
We have identified that this exception is caused due to a missing dll that is on the dependency list of libgfxunity.dll. You can use the following tool:
http://www.ntcore.com/exsuite.phpto view the dependency tree of our dll.
If you get the “dll not found” exception, it is likely that d3dx9_43.dll is missing on the target computer, which is causing the main integration dll to not load.
You should be able to rectify this problem by just downloading the latest
DirectX runtime. We will soon supply the complete integration package which will allow you to rebuild the dll on your machine. In this case, the generated libgfxunity3d.dll will automatically have the correct dependency.
Thanks and please let us know if you encounter any other problems with using the integration.
-Ankur
