I use Scaleform 4.5 and I am trying to build Scaleform\GFx SDK 4.5\Apps\Tutorial\Section3.5\Section_3.5_Msvc10.vcxproj (it's called Msvc10 but I open it with Visual 2015 so Visual reconfigured the project,... it's ok).
The problem is that it complains about libgfx.lib : error LNK2019 : unresolved external symbol (10 times).
My libgfx.lib is dated on 7th of September 2016. I built "GFx 4.5 Kits.sln", "GFx 4.5 Demos.sln" and "GFx 3rd Party.sln" but no one rebuild that libgfx.lib !
My question is how to rebuild this lib? Is there a project in Scaleform to do that?
No answer so more precisions maybe.
I followed :
http://help.autodesk.com/view/SCLFRM/ENU/?guid=__scaleform_help_integration_tutorial_integration_ins...
and
to use Scaleform in my project. When I compile, I have links errors due to
#include "GFx.h"
libgfx.lib(Amp_Message.obj) : error LNK2019: unresolved external symbol _deflate referenced in function "public: virtual bool __thiscall Scaleform::GFx::AMP::Message::Compress(class Scaleform::Array<unsigned char,2,struct Scaleform::ArrayDefaultPolicy> &)const " (?Compress@Message@AMP@GFx@Scaleform@@UBE_NAAV?$Array@E$01UArrayDefaultPolicy@Scaleform@@@4@@Z) libgfx.lib(Amp_Message.obj) : error LNK2019: unresolved external symbol _deflateEnd referenced in function "public: virtual bool __thiscall Scaleform::GFx::AMP::Message::Compress(class Scaleform::Array<unsigned char,2,struct Scaleform::ArrayDefaultPolicy> &)const " (?Compress@Message@AMP@GFx@Scaleform@@UBE_NAAV?$Array@E$01UArrayDefaultPolicy@Scaleform@@@4@@Z) libgfx.lib(Amp_Message.obj) : error LNK2019: unresolved external symbol _inflate referenced in function "public: virtual bool __thiscall Scaleform::GFx::AMP::MessageCompressed::Uncompress(class Scaleform::Array<unsigned char,2,struct Scaleform::ArrayDefaultPolicy> &)" (?Uncompress@MessageCompressed@AMP@GFx@Scaleform@@UAE_NAAV?$Array@E$01UArrayDefaultPolicy@Scaleform@@@4@@Z) libgfx.lib(Amp_Message.obj) : error LNK2019: unresolved external symbol _inflateEnd referenced in function "public: virtual bool __thiscall Scaleform::GFx::AMP::MessageCompressed::Uncompress(class Scaleform::Array<unsigned char,2,struct Scaleform::ArrayDefaultPolicy> &)" (?Uncompress@MessageCompressed@AMP@GFx@Scaleform@@UAE_NAAV?$Array@E$01UArrayDefaultPolicy@Scaleform@@@4@@Z) ... fatal error LNK1120: 54 unresolved externals
So as I said, I try to rebuild libgfx.lib but there is apparently nothing to do that. Any ideas?
