Trying to integrate Scaleform
05:01 AM
I try to use Scaleform with Urho3D but I am stuck because of Scaleform crashing at initialization.
I use the example "tessellation" and more precisely the file GFxPlayerGL.cpp and GFxPlayerGL.h, and I add them to my project.
So in my main function, I have :
Scaleform::SysAllocMalloc a; Scaleform::GFx::System gfxInit(&a); gfxplayer = new Scaleform::GFxPlayer(); int gfxInitError = gfxplayer->Init(); if (gfxInitError) return gfxInitError;
And the function in GFxPlayerGL.cpp :
int GFxPlayer::Init() { // Configure Loader. // Developers set states on the loader to modify loading and playback behavior. // If you need to load files from a custom package, for example, you can // create a FileOpener derived class that loads files in a custom way. // Here FileOpener is set for demonstration purposes, but a default instance of this FileOpener // is installed in the loader already. Ptr<GFx::FileOpener> pfileOpener = *new GFx::FileOpener; mLoader.SetFileOpener(pfileOpener); // Install the customized logging function, which prints output to the console. mLoader.SetLog(Ptr<GFx::Log>(*new GFxPlayerLog())); #ifdef SF_OS_WIN32 // Install the Win32 font providier, which can pull font definitions from installed system fonts. Ptr<GFx::FontProviderWin32> fontProvider = *new GFx::FontProviderWin32(::GetDC(0)); mLoader.SetFontProvider(fontProvider); #endif // Install the image handler libraries (with all available format handlers), which allows loading images from different types. Ptr<GFx::ImageFileHandlerRegistry> pimgReg = *new GFx::ImageFileHandlerRegistry(GFx::ImageFileHandlerRegistry::AddDefaultHandlers); mLoader.SetImageFileHandlerRegistry(pimgReg); // Install the custom DemoExternalInterfaceHandler, which will process callbacks from the GFx content. Ptr<GFx::ExternalInterface> pEIHandler = *new DemoExternalInterfaceHandler; mLoader.SetExternalInterface(pEIHandler); // Install support for both AS2 and AS3 script. If only targetting one language, you can omit the unused one. Also, GFx can be // recompiled with GFX_AS2/AS3_SUPPORT undefined in GFxConfig.h, to reduce copmiled library size (source customers only). Ptr<GFx::ASSupport> pAS2Support = *new GFx::AS2Support(); mLoader.SetAS2Support(pAS2Support); Ptr<GFx::ASSupport> pASSupport = *new GFx::AS3Support(); mLoader.SetAS3Support(pASSupport); // Allocate the ThreadCommandQueue, which is an interface for sending rendering commands to the rendering thread. This sample is // single threaded, so the ThreadCommandQueue is very simple, executing all commands immediately. For multi-threaded execution, // the implementation of this class must be thread safe. /********************************/ //CRASH RANDOMLY BETWEEN HERE Render::SingleThreadCommandQueue* queue = new Render::SingleThreadCommandQueue(); //CRASHES HERE pCommandQueue = queue; // Create renderer. Ptr<Render::GL::HAL> phal = *new Render::GL::HAL(pCommandQueue); pRenderHAL = phal; // Give the command queue pointers to the HAL queue->pHAL = pRenderHAL; //SOMETIMES CRASHES HERE // Configure renderer in "Dependent mode", honoring externally // configured device settings. if (!phal->InitHAL(Render::GL::HALInitParams())) return 1; //AND HERE /*******************************************/ // Load the movie file into a GFx::MovieDef. pMovieDef = *mLoader.CreateMovie(FXPLAYER_FILENAME); if (!pMovieDef) { String alternateFilename = "../Debug/";//"../bin/"; alternateFilename += FXPLAYER_FILENAME; if (!(pMovieDef = *mLoader.CreateMovie(alternateFilename))) { String errorString = "Unable to load file: "; errorString += FXPLAYER_FILENAME; MessageBoxA(NULL, errorString.ToCStr(), "Error", MB_OK | MB_ICONEXCLAMATION); return 1; } } // Now create the GFx::Movie from the loaded GFx::MovieDef. pMovie = *pMovieDef->CreateInstance(GFx::MemoryParams(), 0, 0, pCommandQueue); if (!pMovie) { return 1; } hMovieDisplay = pMovie->GetDisplayHandle(); // Indicate to the Movie that there is exactly one mouse. pMovie->SetMouseCursorCount(1); // If you wanted to use the movie as a transparent HUD overlay, you would set background alpha to zero. If you want to // see the Stage, then the background alpha should be higher than zero. In this sample, we do not want the stage to // obscure the 3D rendering, so we set its alpha to zero. pMovie->SetBackgroundAlpha(0.0f); // Store initial timing, so that we can determine // how much to advance Flash playback. MovieLastTime = timeGetTime(); return 0; }
It crashes, making Visual Studio 2015 to crash too, so I can't have any debug information. If I put a breakpoint before in order to go step by step, I don't notice anything, and at one point, it crashes, and exits.
Any ideas?
