The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Scaleform: Undefined symbols for architecture x86_64
When I compile scaleform 4.3.28 for MacOS+clang/x86_64 with some minor changes with FlashPlayerFX (which compiles fine for linux), I receive this error:
Undefined symbols for architecture x86_64:
  "Scaleform::Platform::Device::dumpScreen(Scaleform::File*)", referenced from:
      Scaleform::Platform::RenderHALThread::dumpScreen(Scaleform::File*) in libgfxplatform.a(Platform_RenderHALThread.o)
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: *** [Bin/MacOS-x86_64/clang/FxPlayer.app/Contents/MacOS/FxPlayer] Error 1
make: *** [Release+NoRTTI] Error 2
I am unsure how to proceed, please let me know if you need any more information.
Here is my log output:
make P=MacOS+clang/x86_64 clean rebuild
\e]0;Making scaleform_4.3_macos_twcrm -rf Obj/MacOS-x86_64-clang/Release_NoRTTI  Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxrender_gl.a Bin/MacOS-x86_64/clang/FxPlayerTiny.app Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxsound_fmod.a Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxsound_null.a Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxexpat.a Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxplatform.a Lib/MacOS-x86_64/clang/libcurl.a Lib/MacOS-x86_64/clang/libpcre.a Bin/MacOS-x86_64/clang/FxPlayer.app Bin/MacOS-x86_64/clang/HudDemo.app Bin/MacOS-x86_64/clang/MenuDemo.app
rm -rf Obj/MacOS-x86_64-clang/Debug_NoRTTI  Lib/MacOS-x86_64/clang/Debug_NoRTTI/libgfxrender_gl.a Bin/MacOS-x86_64/clang/FxPlayerTiny_Debug_NoRTTI.app Lib/MacOS-x86_64/clang/Debug_NoRTTI/libgfxsound_fmod.a Lib/MacOS-x86_64/clang/Debug_NoRTTI/libgfxsound_null.a Lib/MacOS-x86_64/clang/Debug_NoRTTI/libgfxexpat.a Lib/MacOS-x86_64/clang/Debug_NoRTTI/libgfxplatform.a Lib/MacOS-x86_64/clang/libcurl.a Lib/MacOS-x86_64/clang/libpcre.a Bin/MacOS-x86_64/clang/FxPlayer_Debug_NoRTTI.app Bin/MacOS-x86_64/clang/HudDemo_Debug_NoRTTI.app Bin/MacOS-x86_64/clang/MenuDemo_Debug_NoRTTI.app
rm -rf Obj/MacOS-x86_64-clang/DebugOpt_NoRTTI  Lib/MacOS-x86_64/clang/DebugOpt_NoRTTI/libgfxrender_gl.a Bin/MacOS-x86_64/clang/FxPlayerTiny_DebugOpt_NoRTTI.app Lib/MacOS-x86_64/clang/DebugOpt_NoRTTI/libgfxsound_fmod.a Lib/MacOS-x86_64/clang/DebugOpt_NoRTTI/libgfxsound_null.a Lib/MacOS-x86_64/clang/DebugOpt_NoRTTI/libgfxexpat.a Lib/MacOS-x86_64/clang/DebugOpt_NoRTTI/libgfxplatform.a Lib/MacOS-x86_64/clang/libcurl.a Lib/MacOS-x86_64/clang/libpcre.a Bin/MacOS-x86_64/clang/FxPlayer_DebugOpt_NoRTTI.app Bin/MacOS-x86_64/clang/HudDemo_DebugOpt_NoRTTI.app Bin/MacOS-x86_64/clang/MenuDemo_DebugOpt_NoRTTI.app
rm -rf Obj/MacOS-x86_64-clang/Shipping_NoRTTI  Lib/MacOS-x86_64/clang/Shipping_NoRTTI/libgfxrender_gl.a Bin/MacOS-x86_64/clang/FxPlayerTiny_Shipping_NoRTTI.app Lib/MacOS-x86_64/clang/Shipping_NoRTTI/libgfxsound_fmod.a Lib/MacOS-x86_64/clang/Shipping_NoRTTI/libgfxsound_null.a Lib/MacOS-x86_64/clang/Shipping_NoRTTI/libgfxexpat.a Lib/MacOS-x86_64/clang/Shipping_NoRTTI/libgfxplatform.a Lib/MacOS-x86_64/clang/libcurl.a Lib/MacOS-x86_64/clang/libpcre.a Bin/MacOS-x86_64/clang/FxPlayer_Shipping_NoRTTI.app Bin/MacOS-x86_64/clang/HudDemo_Shipping_NoRTTI.app Bin/MacOS-x86_64/clang/MenuDemo_Shipping_NoRTTI.app
/Applications/Xcode.app/Contents/Developer/usr/bin/make P=MacOS+clang/x86_64 C=Release+NoRTTI
  cc     Src/Render/GL/GL_HAL.cpp
  cc     Src/Render/GL/GL_MeshCache.cpp
  cc     Src/Render/GL/GL_Shader.cpp
  cc     Src/Render/GL/GL_Sync.cpp
  cc     Src/Render/GL/GL_Texture.cpp
  cc     Src/Render/GL/GL_ShaderDescs.cpp
  cc     Src/Render/GL/GL_ShaderSource.cpp
  cc     Src/Render/GL/GL_Extensions.cpp
  ar     Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxrender_gl.a
  cc     Apps/Samples/GFxPlayerTiny/GFxPlayerTinyMacGL.mm
Apps/Samples/GFxPlayerTiny/GFxPlayerTinyMacGL.mm:387:15: warning: 'loadNibNamed:owner:' is deprecated: first deprecated in OS X 10.8
      [-Wdeprecated-declarations]
    [NSBundle loadNibNamed:@"MainMenu" owner:NSApp];
/System/Library/Frameworks/AppKit.framework/Headers/NSNibLoading.h:30:1: note: 'loadNibNamed:owner:' has been explicitly marked
      deprecated here
+ (BOOL)loadNibNamed:(null_unspecified NSString *)nibName owner:(null_unspecified id)owner NS_DEPRECATED_MAC(10_0, 10_8); // Depr...
1 warning generated.
  cc     Src/XML/XML_Expat.cpp
  ar     Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxexpat.a
  cc     Src/Platform/Platform.cpp
  cc     Src/Platform/Platform_CommandLine.cpp
  cc     Src/Platform/Platform_CoreTest.cpp
  cc     Src/Platform/Platform_RenderThread.cpp
  cc     Src/Platform/Platform_RTCommandQueue.cpp
  cc     Src/Platform/Platform_SystemCursorManager.cpp
  cc     Src/Platform/Platform_Posix.cpp
  cc     Src/Platform/Platform_RenderHALThread.cpp
  ar     Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxplatform.a
  make   Obj/MacOS-x86_64-clang/3rdParty/curl-7.29.0/libcurl.a
  make   pcre
  ld     Bin/MacOS-x86_64/clang/FxPlayerTiny.app/Contents/MacOS/FxPlayerTiny
  cc     Src/Sound/Sound_SoundRenderer.cpp
  cc     Src/Sound/Sound_Sound.cpp
  cc     Src/Sound/Sound_SoundRendererFMOD.cpp
  ar     Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxsound_fmod.a
  ar     Lib/MacOS-x86_64/clang/Release_NoRTTI/libgfxsound_null.a
  cc     Src/Platform/Platform_Mac_GL.mm
Src/Platform/Platform_Mac_GL.mm:283:15: warning: 'NSOpenGLPFAFullScreen' is deprecated: first deprecated in OS X 10.6
    attr[3] = NSOpenGLPFAFullScreen;
/System/Library/Frameworks/AppKit.framework/Headers/NSOpenGL.h:84:2: note: 'NSOpenGLPFAFullScreen' has been explicitly marked deprecated
      here
        NSOpenGLPFAFullScreen NS_ENUM_DEPRECATED_MAC(10_0, 10_6)       =  54,
Src/Platform/Platform_Mac_GL.mm:300:10: warning: 'setFullScreen' is deprecated: first deprecated in OS X 10.7 - Use a fullscreen
      NSOpenGLView instead [-Wdeprecated-declarations]
    [ctx setFullScreen];
/System/Library/Frameworks/AppKit.framework/Headers/NSOpenGL.h:212:1: note: 'setFullScreen' has been explicitly marked deprecated here
- (void)setFullScreen NS_DEPRECATED_MAC(10_0, 10_7, "Use a fullscreen NSOpenGLView instead");
Src/Platform/Platform_Mac_GL.mm:903:15: warning: 'loadNibNamed:owner:' is deprecated: first deprecated in OS X 10.8
      deprecated here
3 warnings generated.
  cc     Apps/Samples/FxPlayer/FxPlayer.cpp
  cc     Apps/Samples/Common/FontConfigParser.cpp
  cc     Apps/Samples/Common/FxPlayerAppBase.cpp
  cc     Apps/Samples/Common/FxPlayerAppBaseHUD.cpp
  cc     Apps/Samples/Common/FxPlayerAutotest.cpp
In file included from Apps/Samples/Common/FxPlayerAutotest.cpp:19:
Apps/Samples/Common/FxPlayerAutotest.h:44:22: warning: private field 'App' is not used [-Wunused-private-field]
    FxPlayerAppBase* App;
  cc     Apps/Samples/Common/FxRenderThread.cpp
  cc     Apps/Samples/FxPlayer/FxHUD.cpp
  cc     Apps/Samples/Common/FxSharedObjectManager.cpp
  cc     Apps/Samples/Common/FxAmpAppControlCallback.cpp
  cc     Apps/Samples/Common/FxSoundFMOD.cpp
  ld     Bin/MacOS-x86_64/clang/FxPlayer.app/Contents/MacOS/FxPlayer
Attached is the verbose log output.
Replies (0)
