I have problem when assign thikness panel. First do a poliline (contour is the same problem), then click on panel option, assign the material, thickness and i choose plate. The program create the panel but like the image in the link (¿?), without thickness.
When i try to change manually in the left (inspector objets) the plate dissapears.
Help please, i try everything.
Thanks.
Solved by teixeiranh. Go to Solution.
