Is it possible for me to take a panel cut between finite element mesh nodes?
Im trying to use "panel cut between two points" but Robot wont let me snap to the mesh node points?
I can only seem to snap to the structure axis, which is at 6.0m centres and is therefore useless, as I want to get detailed info over smaller areas <1.0m.
I am in the Results>Maps>Open new window with scaled display View,
Does anyone else experience this?
P.s. I have messed around witjh snap setting but doesnt seem to work??
Solved by ByrnePM. Go to Solution.
I have changed my view to the main geometry screen and it is now letting me snap to the desired points EXCEPT:
When I pick the two points and the axis I want, ROBOT shows me nothing ...no panel cut at all?
Ive decided its best not to pick two points that are in the exact direction of the axis you chose ...crisis over ...it works fine now
