Panel contour points modification (API)
sergey.churilov
sergey.churilov
Is there any way to present panel contour points (coordinates X, Y, Z) in a table like the table available for nodes?
I do not want table for each individual panel, but a table which presents all contour points for all defined panels in a model on one sheet.
This could be helpful for fast correction of the contour points coordinates, especially in cases without precise geometry where the 9th decimal place at a coordinate makes all the difference between a good or bad mesh.
Replies (26)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Ordinary rounding, rounding up and rounding down in attached xls
(choice by radiobuttons on top)
Rafal Gaweda
t.sautierr
Thx Rafal!
Is it possible to have your source code of the round up addin (the one with .dll)
This one is even more better as it can round also bars coordinates and points. I'd like to implement the round up and down in it.
Thanks again.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, I will post it as soon as possible.
I have already implemented Up and Down in it.
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal.Gaweda
Autodesk Support
Autodesk Support
Update
Faster objects update
Rafal Gaweda
Hi. I am constantly getting inconsistent mesh errors with panels drawn over .dwg backgrounds. I was hoping that your macro would prove to be the solution to this but I'm getting an error when I try import the panels into the excel sheet (see attached photo). Any idea how to fix this? Thanks, Colm
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check this thread:
http://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geometr...
If it does not help please tell me which Robot version do you use and post Robot file to check it
Rafal Gaweda
