Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load transfer slab to beam and beam offset
9 REPLIES 9
Message 1 of 10
4289 Views, 9 Replies
I am analysing concrete slab supported by two metal beams.
I have created test model with 4 storeys:
Story 4 - concrete slab + metal beams without offset
Story 3 - concrete slab + metal beams with offset
Story 2 - cladding + metal beams without offset
Story 1 - cladding + metal beams with offset
Problems I have:
1. Storyes 3 and 4 - slabs do not transfer load.
2. Story 1 - How to avoid moments over supports.
Can you help me with this?
Here is the link to the model: http://www.4shared.com/file/sXm7Z-i5/TEST_MOD_0_0.html
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
Wrong load type - must be any (FE)... load
Rafal Gaweda
Message 4 of 10
in reply to: Rafal.Gaweda
Thanks for answering question No.1.
For question No.2:
I am trying to get results like on Story 2 - beam independant from the slab.
To be precise, I want to transfer the load from the slab to the beam without two of them "working together".
How can I model this?
3. Additional question: Is there a way to show beam with offset without influence to the calculations? I need it for presentation purposes
Message 5 of 10
Rafal.Gaweda
Either make two models or use Word or PowerPoint to "prepare correct" presentation making screen shots from Robot.
Rafal Gaweda
Message 6 of 10
Rafal.Gaweda
If I understood you correclty:
- there is no slab on Story 2 (only cladding) so the beams works independent
Whatever
- you may use panel with calculation model like that (such or similar settings (Stiffening in XY)):
- or use Linear releases on panels edges
or like in message 5:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Meshed-slab-supported-by-beams/m-p/3167096/h...
Rafal Gaweda
Message 7 of 10
I want to know if there´s a way to see the loads diagrams caused by a slab on a border beam.
Thanks.
Message 8 of 10
Artur.Kosakowski
Hi @Anonymous
For a meshed panel only if you model them at the different levels as connected with rigid links or short vertical bars and then you check the forces in these 'connectors'.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 9 of 10
in reply to: Artur.Kosakowski
I found a way to do this.
Just go to Display -> Loads -> tick "Forces Generated Automatically". Then activate "Load Value Descriptions" bottom at the lower left, and you will see the load patterns generated on frames as a result of loads transfered from slabs or claddings.
Message 10 of 10
Artur.Kosakowski
Hi @Anonymous
Mind that this is valid only for the triangular and trapezoidal (tributary area) load distribution method and cannot be used for load being "transferred"  via surface elements (based on the structure deformation/rigidity).
Artur Kosakowski
