In Job Preferences/Materials I select Modification. In Material Definition I create new material, press Add and Ok. If I again select Modification button I see new material. But if I close Job Preferences dialog and open it again - created new material is missing. How to save the new Materials? (Windows 8 64 and ARSAP 2013)
if it were that simple, I do not would write here :). It is nothing unworthy answer.
Try to clear cfgusr folder before next robot start.
Movie: http://screencast.com/t/STws1m09iJ
I am facing the same problem on my PC (Windows 8 64 BIT RSAP 2013). I had this issue also on PC in my university (Windows 7 64 BIT RSAP 2013). I tried restarting program and deleting all files from mentioned folder. Doesn't work for me.
PLasky,
IN your case please check whether the file
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\rmat048.xml
is changed after closing robot (and of course after creating new material before) or not.
If not, ask Administrator to check privilages you have to write \ modify this folder and \ or check firewalll \ antivirus settings.
I can not explain, but the problem is solved as follows: I create a new user with administrator rights, in his environment installs Autodesk Robot, go back to my environment and enjoy my success ...
