Hi. I have a model file in CBS .geo, only with current geometry, 4 stores, about 700m2 per floor. I have only introduce geometry (walls, slabs, beams, columns). Not any loads yet. The file grows up to 450MB and it become impossible to work with.
Can i have some help?
Also, I use CBS for AVP (avant projet). How can I represent the impact of the stucture that begins above the current level? P. ex, I have some deep beams that ar above the current level but i cannot see it, nor be presented on plans as "the impact of upper structure".
Thanks.
Solved by Artur.Kosakowski. Go to Solution.
Do you have some backgrounds? If, yes, what is the size of the file when you delete them?
What about modelling the "impact' as additional loads?
1. I can't think of any option that would reduce the size of the model with backgrounds but delete the ones that are currently not needed.
2. You may want to try View > Previous/Next story commands.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
