Thank you for the confirmation.
Just a summary of effects in Revit2Robot link discussed in this post and their current status - may be useful for others too
Effects improved in RSA 2015 SP3
Related to defining linear or surface supports - some possible scenarios below
A. For line supports
1/ Defining in Revit the structure containing walls and slabs
2/ Transfer to Robot
3/ Defining in Robot line support and running analysis
4/ Transfer to Revit
5/ Transfer to Robot - the message "Incoming model differs significantly from the updated model" and duplicated elements
B. For surface supports
3/ Defining in Robot surface support and running analysis
4/ Transfer to Revit - the message "Incoming model differs significantly from the updated model" and duplicated elements
Effects still observed in RSA 2015 SP3
A. Related to automatic combinations - as the scenario below:
1/ creating any structure in Revit
2/ transfer to Robot
3/ defining in Robot automatic code combinations and runing analysis
4/ transfer back to Revit: the message "Incoming model differs significantly from the updated model" is displayed and doubled elements are created in Revit
B. Related to generating in Revit unnecessary isolated foundations - as the scenario below:
3/ Defining in Robot line supports or surface supports and running analysis
4/ Transfer to Revit: except of defining in Revit the line or area boundary conditions the isolated supports are generated in Revit - corresponding to node positions in Robot where line or surface supports existed
Analogous effects observed when the line or area boundary conditions defined in Revit in step 1/
Both these effects were reported to development team to be improved.
I will update this post when any change is available.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Best regards,
Pawel Pulak
Technical Account Specialist
