Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Definition of direction of spectral analysis (rotated)
8 REPLIES 8
Message 1 of 9
joverac
494 Views, 8 Replies
HI, I'm using Revit and Robot integration and I have a problem. I have a model in Revit that is rotated, respect to the axis. When I export this model to Robot Structural, the models takes the axis of Revit and the rotation of the model (aproximately 20º) . I don't have problem with use the rotated model but I need to apply spectral analysis in the direction of the resistant elements. How can I rotate the application of spectral analysis?
8 REPLIES 8
Message 2 of 9
Artur.Kosakowski
in reply to: joverac
In order to get correct results you need to rotate the model and have the directions of seismic/spectral excitations parallel to the global coordinate axes.
Artur Kosakowski
Message 3 of 9
Rafal.Gaweda
See webinar 7, slide 11
Rafal Gaweda
Message 4 of 9
joverac
in reply to: Artur.Kosakowski
I did That before in other structure but I lost the integration with Revit. Is it possible to rotate the direction of spectral application?
Message 5 of 9
Artur.Kosakowski
It is possible by entering the appriopriate values in the direction fields but this is not recommended as the results may be incorrect.
Artur Kosakowski
Message 6 of 9
joverac
Well, In that case I can't apply a different direction of seismic analysis than x and y, for example 45º or 30º. I think is a good idea considere this in next versions.
Message 7 of 9
Artur.Kosakowski
According to my knowledge the by principle this kind of analysis allows you to either:
- have fixed directions and be able to rotate a model (like in RSA)
- be able to enter model with one orientation only and rotate the directions
but you cannot have both at the same time.
Artur Kosakowski
Message 8 of 9
memoalcr
So if a code asks that the horizontal seismic excitation is the vector sum of 100% in the X direction and 30% in the Y directions this is where one defines X: 1 and Y: 0.3 (see image); correct?
Message 9 of 9
Artur.Kosakowski
in reply to: memoalcr
Hi @memoalcr
Correct.
Artur Kosakowski
