Hi everyone,
I'm trying to define a "column-beam" connexion between my middle beam and middle column (file LITTLE STRUCTURE) but the software doesn't want to let me do that.
BEAM D + COLUMNS (LONG SPAN) is another exemple in the same configuration where it works...
Have a nice day,
Mathias.
Solved by mathias_peron. Go to Solution.
Thank you but I'm talking about another connection design. Take a look in attachment.
What bother me is that this connection was available in another project before that was in the same configuration (cf BEAM D + COLUMNS (LONG SPAN)).
Have a nice day,
Mathias.
I'm talking about the middle column and the middle beam but i found the solution, I had to make a 90° rotation with the column and the software propose me the connection.
Thank you for your time!
Mathias.
