RSA / Revit Accurate Interoperability - A Different Approach
I am aware Autodesk is trying to find an optimal way to create a link between RSA and Revit for years. Analytical model creation in Revit nearly always causes accuracy issues due to misaligned nodes/members and FEM simplification.
My opinion on this, why we can't directly export / transfer a 3D solid model of the Revit physical model to RSA for analysis? It should be %100 accurate and there is no need for conversion. RSA has 3D solid model mesh creation and solvers already. 3D solid analysis will be much more realistic due to less simplification and current PCs have much more capable than previous generations. RSA can use AMD/NVIDIA GPUs for computation with updates.
Kindly consider analytical model creation roadmap again. There is no suffice solution for years maybe converting Revit physical model directly to 3D solid with material specs will be much easier and more efficient. This can be done by RSA by directly meshing the Revit physical model and solve it. Why need analytical automation or conversion?
That method is not feasible for most of the time.
