Map ratio bars after ordering the ratios
When you run the calculations for the member verification, you see a table with all the bars, its materials, worst case, ratio etc..
If you press map button the program takes you to a new window with colours indicatin in red for example the ones aro over 1.
BUT, if you first order the bars (double click on the top of the column) then the MAP button doesn't work, Nothing happens.
1 Comment
philip.s
Status changed to: Gathering Support
prior status deleted, setting to default
