Improving Result connect to get envelop values of a bar or member stresses.
Results connect can improved to get max and min stresses for list of loads. As ULS load cases some times need to be entered manually, a set of load will be generated. Picking the max and min from the list of ULS combination is bit difficult to through results connect. The user needs to sort out separately in excel to get max and min values after extracting results to excel sheets.
