3D - model : Foundations display, diagrams etc
-Changing or adding for nodal / linear supports : the size, stiffness, weight (directly). Or better new object for linear.
-Upgrading the graphical results display for supports : cartography (in addition to diagram) or possibility to indicate points to be displayed, min/max values. Still a mess at the time !
-adding Kx and Ky (soil reactions) in map when support is defined in panel thickness + reduced results at rigidity centre of the selected panels, or to a user defined point.
-adding cartography for surface supports (nodal values : impossible to display all these values !), with also reduced results aforementioned
