yield line analysis for slab
efyjw7
Message 1 of 12
efyjw7
Hello professional structural engineer here, I would like to ask about yield line analysis for slabs. Does the yield line I sketch is correct for the square slab with 3 end continuous and 1 end simply supported. Please give me some advice thank you. Sorry for asking some question not related to the software.
Replies (11)
Message 2 of 12
HoshangMustafa
Hi
Is there a workaround to get location and shape of yield line using ARSA?
Message 3 of 12
HoshangMustafa
88 views, no replies.
Message 4 of 12
CaioSaporito
Hi @HoshangMustafa!
I believe there is no workaround since robot doesn´t perform plastic analysis for shell as we can see here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Elasto-Plastic-Ana...
Best regards,
Caio
Message 5 of 12
Rafacascudo
Not exactly ,but this way you will get some clues
It becomes clearer using isolines instead of maps
Rafael Medeiros
Message 6 of 12
HoshangMustafa
Hi @Rafacascudo
Is there a workaround to draw the white lines in your second picture more accurately? If so, can one model it as lines of linear release of moments in these locations?
Message 7 of 12
Rafacascudo
You can make it clearer  changing the settings on the  "scale" tab. Unmark "with normalization" and  adjust scale range on User limits
or even clearer using "isolines with bigger thickness
setting the scale to be more restrict you can see better where the zero shear line is.
yeld lines 6.jpg and using the mesh nodes you can easily create the pinned  release edges
Rafael Medeiros
Message 8 of 12
HoshangMustafa
Hi @Rafacascudo
Thanks. Where's the "Accept as solution" button?
Message 9 of 12
Rafacascudo
Probably it doesn't appear to you because you are not the thread starter. But I can do it for you if you allow me
Rafael Medeiros
Message 10 of 12
HoshangMustafa
Hi @Rafacascudo
Yes, of course, I appreciate your help.
Message 11 of 12
efyjw7
Hey experts here, thanks for the solutions. Actually, i already figured it out via manual hand calculation for the plastic analysis for this slab.
Message 12 of 12
efyjw7
Since the slab B1C2 is pinned or simply supported at one edge, and fixed or continuous at three edge. I provide a sketch here the yield line will try to 'shfit' towards the pinned edge, and I try to equate the internal and external workdone equilibrium to find the max Mp in the slab. The correct value of Mp will be 27.12kNm.
