@eng_leandromartins
What @Stephane.kapetanovic suggested is the best solution.
But if you want to simulate 100% the "real thing" ,then you have to forget about tension only bars because such thing does not exist in the real world.
To simulate as close as possible to the real world ,use regular bars that can have ,axial , shear and moment in all directions with elastic releases in all 6 directions. It is even possible to release compression using regular bars
Much more work compared to the optimal proposed solution by @Stephane.kapetanovic , but ,if done right , it will be possible to divide the bar and not get instability warnings. In the end ,you will get the very same axial tension force on the 2 methods and also 5 more neglegible forces and moments using the regular bars.
Structural modelling ,very often, does not mean that you have to exactly represent what real structure looks like . You just have to have in mind that sometimes compromises have to be made so the model represents and outputs only what is really important to the safety of the structure.
@eng_leandromartins , are you Brazilian?
Rafael Medeiros
