Wring visualisation of axial force diagram
I have a 3d concrete frame structure and for some columns there is a problem displaying their axial force on the diagrams. The axial force diagram seems to "interrupt" at some point and then appear again. As it can be seen from the attached picture for column 36 the axial force above the interruption is 172kN and below 324 kN. However when I open bar properties for that column, the software shows that there is in fact an axial force of around 240 kN, it is just not shown visually.  What do you think the problem can be? I would be grateful for your help.
Thank you,
Valerija
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to switch off the story filter
Artur Kosakowski
