Hello!
I've been running a few tests with the wind simulation, regarding interferences of surrounding objects on the structure, but the results are kind of odd. See the model attached, with a series of 5x5m concrete walls, aligned at different distances. Notice that, with two walls distant 1m from each other, the results of the wind simulation are equal on both of them, like there is no interference whatsoever. The front wall starts to really "blocking" the wind for the back wall only at 4m of distance.
Somebody had the same problem before? Or is that a normal behavior? (Doesn't seem like though.)
That has maybe something to do with the size of mesh used for the wind tunnel? If so, how to adjust to get better results?
