Wind Simulation on Robot structural Analysis
Dear Concerned,
I did two simple wind simulation on Robot Structural analysis, I am getting two different values
1) the first simulation was the same building, wind speed 50 m/s without cladding
2) the second simulation was the same building, wind speed 50m/s, with cladding.
So am posting this message, to know if we should put the cladding before or after the simulation to obtain correct values for wind pressure.
Thanks in advance
 @Anonymous Artur Kosakowski marked the post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If the wind acts on walls (claddings) then before; if not after Smiley Happy
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
