Wind simulation - Error issue - no pressure maps when running
skellyRSA2023
skellyRSA2023
I have tried running the wind simulation on the attached model which is a 16 story building, two separate blocks connected at the bottom. I set the wind pressure etc. and run the wind simulation it runs through the x+ direction simulation and load generation and then into the next direction, then it suddenly stops and I get an error message stating to send error to autodesk. see attached when I run the wind simulation the pressure maps do not show as they usually would when running the wind simulation nor doe the arrow show in the image? has anyone come across this before and if they did what was the issue and how did they get it sorted? Anyones help would be appreciated.
Simon.
skellyRSA2023
I have tried running the model again in the wind simulation and again it stopping have way through. I have attached download link below to the model, if anyone has any suggestions on how I can get it to work it would be appreciated. the outer external perimeter is a mixture of cladding and concrete walls and the base levels are stepped so I tried applying the wind load at the highest base level of 3m in the wind simulation but still it stops and no pressure maps shown during the simulation which leaves me to believe its not working correctly. any help would be greatly appreciated.
Simon.
Download link
https://we.tl/t-9Yvr1JgAXX
StefanoPasquini6790
Hi @skellyRSA2023 ,
The problem is that your model have some unflat panel...
try to correct it, flatting all the panels, to do this you can use the API called flatness that you can find in the API collection page in this forum.
Good luck
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
StefanoPasquini6790
Hi @skellyRSA2023
you have problem with panel 489. See the picture
PasProStudio
skellyRSA2023
Stefano,
thanks you very much for looking at this. I have amended panel 489 and run wind simulation but still does not produce the pressure maps etc. see attached I just amended the edges however this puts other panels out? as there are quite a few inaccuracy in the model. is there an easy way of aligning all the panels up? using the detail correct tool in some way?
since I uploaded the model this morning, I have run the model again, running one direction at a time and then stopping, and saving, and it seems to have generated the wind loads on the building (see attached). however when the wind simulation was running there was no pressure maps showing or arrow point in the wind direction, just a wire frame shown, but seems to have worked? however may this have been down to the size of the model?
Simon.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
yes, or fix coordinates manually
Yes.
Run simulation for these objects only:
8 29to32 174to176 238to337By33 38 39 44 103 133 134 149 184 185 215 237 273to275 277to343By22 353to355 424to426 449to451 474to477 480to492 530to746By72 596to600 662to672 695to710 798to807 869to879 902to917 253 270 295 303 315 316 322 324 326 344 350 351 453 509 510 526 528 531 547 548 557 568 586 592 593 727 728 744 748 749 809 881 934 935 951 953 955 956 1005to1031 1093to1103 1118to1152 1170to1172 1221to1230 1033to1829By199 1292to1302 1317to1351 1369to1371 1420to1429 1491to1501 1516to1550 1105to1702By199 1168to1765By199 1568to1570 1619to1628 1690to1700 1715to1749 1767to1769 1798to1803 1836to1841 1907to1918 1932to1948 1955to1966 1984to1986 2041to2057 2115to2126 2138to2166 2059to2590By177 2097to2628By177 2098to2629By177 2179to2710By177 1826 1827 1830 1982 2181to2183 2225to2234 2292to2303 2315to2343 2358to2360 2402to2411 2469to2480 2492to2520 2535to2537 2579to2588 2646to2657 2669to2697 2712to2714 2716to2719 2766to2772 2801to2803 2832to2841 2853to2867 2896to2898 2709 2734 2757 2760 2761 2763 2774 2795 2797 2812 2813 2870 2871 2894 2940 2941 2945to2949 2953to2961 2987to2992 3016to3027 3034to3053 3055to3078 3080to3092 3097to3102 3110to3112 3119to3251 2981 2983 2998 2999 3270 3277 3284to3292
Rafal Gaweda
