I am trying to check if RSAP wind simulation is capable of considering the funnelling effect of wind pressures between two separate structures with a gap between. First question is using two separate structures not ideal (even correct). Second is, does RSAP wind simulation consider the funnelling of winds between two adjacent structures / openings. I see that it is mentioned that the wind simulation might not be reliable for open structures, but in I use two non-open structures side by side, will it consider it open?
