Where to find Robot Open Standard (API) Documentation?
Message 1 of 12
Greetings!
I would like to know where can I find the Robot Structural API Documentation (Robot Open standard).
Thanks.
Wagner.
@Anonymous Iedited the topic and accepted Rafal's solution for better findability. Artur Kosakowski
Replies (11)
Message 2 of 12
StefanoPasquini6790
Hi Wagner,
You can find everything here: http://forums.autodesk.com/t5/robot-structural-analysis/api-tutorial/td-p/3939601
Cheers and good luck
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 12
But everything is not there! Would be awesome to find the document "Robot Open Standard "
Tnx guys.
Message 4 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Run the installation program of Autodesk Robot Structural Analysis 2016
Click “Install Tools & utilities” button.
Check “Autodesk Robot Structural Analysis Professional SDK” and click install.
Once installed you’ll find help and tutorial in :
Start/Programs/Autodesk/ Autodesk Robot Structural Analysis Professional 2016/SDK
or
install SDK directly from media : \x64\Tools\RSASDK\RSA_SDK.msi
and the path C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 20146\SDK\ to whole SDK, documentation, tutorial
Rafal Gaweda
Message 5 of 12
where is Robot API documentation in 2017?
isnt there any SDK for Robot 2017? Robot Object Model and updates?
these are files and folders under Structural Analysis SDK...
Message 6 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
INstall it from media ...\x64\Tools\RSASDK\
Rafal Gaweda
Message 7 of 12
THANKS !!! Cat Happy
Message 8 of 12
wplais
... according to the Robot SDK "Getting Started Guide Robot API" I should use the MSVS 2008. Is it possible to work with the newer MSVS versions, 2012 for example. I ask because my main project is in the 2012 platform and it woul be perfect to have all the projects in the same platform.
Thanks.
Message 9 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
It should not be any issue using MSVS2012
Rafal Gaweda
Message 10 of 12
wplais
Ok. Thank you.
Is there any way to identify the version of the ROBOTOM intalled and running on my machine?
Message 11 of 12
I found there is two "Robotom.tlb" files in my install directory.
#  C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2017\SDK\Wizards\RCDesign\VCINSTALLDIR\VCWizards\AppWiz\RCDesign\Templates\1033\robotom.tlb
and another one in ...
#C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2017\System\Exe\robotom.tlb
Wich one should I use in my project?
Message 12 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
