What would be the smartest way to solve this? (Rotation on an arched structure)
I need to rotate the beams that are on this arched structure so that they are 90 degrees on the arched surface. In picture they're almost 90 degrees, but off by 1 or 2 degrees, my problem is that its hard for me to get them to be exactly 90 degrees. Only way I can get them to rotate is by using the "Rotation" function, but I find this clunky as I cant use XY,XZ or YZ plane to rotate since its an arched structure. I can use the nodes around the beam to get axis beginning and axis end points, but that still becomes a bit inaccurate. Do you guys have any suggestions on how I could solve this problem to get the beams to stand 90 degrees or very close to 90 degrees?
Edit: I have tried the "GAMMA Angle" function, but it does not rotate the actual beam geometry which is what I need.
