What is the difference between the function of planar load and planar load on contour
efyjw7
Message 1 of 9
efyjw7
Hi everyone, let say all the slabs at this floor is subjected to a same load of 5kN/m2, which type of load should i apply (uniform planar or uniform planar on contour) ? I have tried both and both give me different result during analysis. Can someone expert here explain to me the difference between the two function here, thanks.
Replies (8)
Message 2 of 9
efyjw7
Hi everyone, let say all the slab at this floor will be subjected with the same load of 5kN/m2. Which load function should i use? Is it uniform planar load function where i applied the load to each slab or i can just use the uniform planar load on contour function where i applied the load to every slab at this floor at once? Because i tried both function and both give me different end result during analysis. Thanks
Message 3 of 9
Romanich
Hi @efyjw7
The results should be the same. In your case Uniform planar load is the best option.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 4 of 9
Stephane.kapetanovic
hi @efyjw7
no difference except that one is simpler to implement but depending on how the points of the contour load are defined with regard to the contour as well as which object is loaded, this can have unexpected results. Could you share your model ?
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 5 of 9
efyjw7
Thanks for your suggestion sir initially I also think that I should be getting the same result but end out is different result.
Message 6 of 9
efyjw7
Hi sir thanks for the advice actually I made two model with these two methods and the analysis result is different from another I can share the two models here. Maybe I made some mistakes when applying the load
Message 7 of 9
efyjw7
Here are the model with different method, kindly check the result for ULS at these two model. It shows different result for ULS.
Message 8 of 9
Romanich
Hi @efyjw7 ,
You didn't properly assign load on contour:
As you have separated slabs within one floor, the list for LL1 for example should looks like  502to504 506to510 512to516 518 519 521to523 525to529 531to535 537to541  instead of 535
Roman Zhelezniak
Message 9 of 9
efyjw7
I see, thanks for pointing out.
