what does this symbol mean ?
risefire12
risefire12
hi,
i want to ask what does this symbol means ?
Replies (12)
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
It is nodal support symbol (vertical displacement blocked-line, rotations around horizontal  axes blocked-squares)
Krzysztof Wasik
risefire12
this symbol comes out when i use a partial rigid diaphragm (stiffened in XY Plan) ... its normal right ?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
It is correct for rigid diaphragm. Symbol is generated automatically in the middle of XY rigid diaphragm. In that case it shows directions not blocked by diaphragm (UZ, RY and RX) for diaphragm nodes.
Krzysztof Wasik
risefire12
thnk u so much for ur reply... i have another question plz
when i assign the rigid diaphragm i get the warning message " cohesion of the calculation model has been provided by definition of the kinematic constraints" ...and when ever i remove the diaphragm the warning message dissapear... is there explanation plz ?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
Reported warning suggest problem with meshing. If you will click in message program should select FE with incoherent mesh. Share model for verification.
Krzysztof Wasik
risefire12
when i click on the warning message it select the nodes of the diaphragm... this is why when i remove the diaphragm the warning message disappear.
plz find attached model
risefire12
i also viewed the kinematic constraints in the display settings and this is the location of the kinematic
risefire12
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
Model is correct . Warning can be removed by
- freezing mesh using Analysis >Meshing>Mesh Freeze (for all panels)
- swithing off Kinematic constrains in incoherence points  in Tools >Job Preferences >Meshing (then OK)
Krzysztof Wasik
risefire12
thnk u very much for lookin up on my model
can you explain plz why this warning message was appearing ? and also when i should leave it on ( kinematic constraints) ?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @risefire12
Warning is reported while Model Generation. Dummy calculation nodes generated for diaphragm simulation, are indicated as incoherence points. In my opinion it is false warning. When I run model calculation more than once (with no changes), warning is not reported while second (and next) calculations.
Such a warning is reported for models with incoherent mesh on panel edges . In your model mesh is correct (at least as far as I can see). Even if this warning is reported it can be ignored.
Krzysztof Wasik
risefire12
thnk you very much !
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
