I just want to ask what is AY and AY in table properties in the bar tab.
@mustafahesenow Artur Kosakowski edited the topic for better findability
Solved by Artur.Kosakowski. Go to Solution.
Hi Mustafa,
They are shear area in Y and Z directions respectively.
This is my first time hear about shear area the properties shown above its for column 1000 mm x 1000 mm
How this values calculated.
Hi Mustafa,
Please check:
post 7 from Shear Area
and
Calculations of Properties for Selected Section Types
