Web stability at compression
DFN_
Message 1 of 1
DFN_
Hello
Doesn't the software recognize the neighbouring stiffeners when checking web stability at compression in detailed design?
My calculation is not approved when having a force that's only 20 mm from a neighbouring stiffener.
When placing the stiffener in exact position as the force, the web stability under force check isn't checked.
See attached pictures from my case.
/David
Replies (0)
