Wall Selection by VBA (API)
faisal.aaouatif
faisal.aaouatif
Good Moorning / evening
im trying to select walls by using VBA , by no way.
i managed to do selection with bars by using Robotbar object and Robobarcollection but can't find a way to do it with walls.
Help appreciated.
Rafal.Gaweda
Autodesk Support
Autodesk Support
wall = panel with certain reinforcement or thickness properties (labels) - select by appropriate labels
or wall by structural type
Rafal Gaweda
faisal.aaouatif
by object type please.
Thank you
Rafal.Gaweda
Autodesk Support
Autodesk Support
My mistake - by structural type I_OST_WALL
Dim OC As RobotObjObjectCollection
Set OC = RobApp.Project.Structure.Objects.GetAll
Dim Obj As RobotObjObject
Dim OBJSelString As String
For I = 1 To OC.Count
    Set Obj = OC.Get(I)
    If (Obj.StructuralType = I_OST_WALL) Then OBJSelString = OBJSelString + " " + Str(Obj.Number)
Next I
MsgBox OBJSelString, vbInformation
Rafal Gaweda
faisal.aaouatif
it works ( wall panels should be defined as walls in the object inspector  )
Thank you Very much
