Volumetric design supports
I'm creating nodes for a slab at places where I want the supports to be but the meshing of a solid slab doesn't follow those nodes which means the nodes are isolated. How can I create the supports where I want them?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Thank you very much. Now a problem that surfaced is how do I get the slab mesh work with a column that is on it? The picture I attached depicts the problem. When I mesh the slab it does not take the column in to account.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Thank you very much, sir!
