Vertical Seismic Load
Alireza.Kord
Alireza.Kord
HELLO!
I want to create vertical seismic load in equivalent lateral force method, depend on AISC 7-10
Ev=0.2*Sds*D
and then load combination change to
(1.2 + 0.2Sds)D + ρQE + L + 0.2S
(0.9 – 0.2Sds)D + ρQE + 1.6H
so
if Sds=1.05
then
(1.41)D + ρQE + L + 0.2S
(0.69)D + ρQE + 1.6H
now my question is how robot can create load combination included vertical seismic load automatically (because of using DAM analysis method and a lot of load combination I don’t want to create all load combination manually)
P.S.
can’t use load case coefficient in full automatic combination menu because of 2 different factors for dead load
MANY THANKS
Alireza.Kord
BUMP!
no idea for Vertical Seismic Load!
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm sorry but my knowledge of US code is not good enough to correctly understand the situation. First of all could you point me to teh reference in the code which describes the rules for:
Ev=0.2*Sds*D
and then the part that covers generation of combinations:
so
if Sds=1.05
then
Thank you.
Artur Kosakowski
Alireza.Kord
I attached the page is related to it in post no2
Its Page 86 Section 12.4.2.2 (Vertical Seismic Load Effect) and 12.4.2.3 (Seismic Load Combinations) of Chapter 12 (SEISMIC DESIGN REQUIREMENTS FOR BUILDING STRUCTURES) in ASCE 7-10
thanks in advance
Alireza.Kord
BUMP
Really!!!
Robot cant generates load combinations according to ASCE for a seismic region automatically and I have to create 100 load combinations manually
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
structural.engineer79
Not clear
