Variable imported section
jpereira30
jpereira30
Hi!
I created two different sections on section definition, as you can see in the images 1 and 2.
I would like to know if it is possible, in a single element bar, to make a smooth/linear transition from one section to another, instead of doing what's is shown on image 3 (created different bars with variable section). Thank you.
112233
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @jpereira30
Smoth/linear  transition (as expected by you) is not possible in Robot for user defined sections. It can be simulated by series of sections with different (but constant along bar length) diameters.
Krzysztof Wasik
