Using User defined labels
faisal.aaouatif
faisal.aaouatif
Hi
How can we import defined labels used in an other computer or a lower version of RSA ?
Thx
Rafal.Gaweda
Autodesk Support
Autodesk Support
Use Label Manager, on many dialog windows you can access it, select type of labels (green rectangle below), move labels from right hand side panel to left one..
After closing robot copy this file between version folders
Example:
copy
"c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\CfgUsr\labelmng.rtl"
to
"c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\"
Rafal Gaweda
faisal.aaouatif
Thank you very much
