User defined member stability check
andgalb
andgalb
Hi
I have created a member in section builder to represent lost section due to corrosion. The steel design carries out the SECTION CHECK but not the MEMBER STABILITY CHECK. This is therefore giving me a lower ratio for the corroded member (0.22) than the uncorroded member (0.26). How do I check the stability of the member?
Andrew
Artur.Kosakowski
Autodesk Support
Autodesk Support
Have you assigned this section the I symbol saving it to the user database?
Artur Kosakowski
andgalb
Hi Artur
When I select an I section it requires new dimensions to be inserted in the "Saving Section to Database" which only allows me to insert one thickness for both flanges. I'm assuming that I have to make both flanges the thickness of the corroded lower flange?
StefanoPasquini6790
why don't you use this kind of section:
This can solve your issue.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Artur.Kosakowski
Autodesk Support
Autodesk Support
That would be one of the options but I think that the approach suggested by
http://forums.autodesk.com/t5/robot-structural-analysis/how-to-create-thin-walled-sections/td-p/3107...
Artur Kosakowski
andgalb
Thanks Gents that has done the trick.
HI ARTHUR,
Capture.JPGKINDLY HELP ON THIS AS WELL. THANKS FOR THE USUAL SWIFT RESPONSE.
