User Coefficient Seismic Load Pattern
Alireza.Kord
Message 1 of 14
Alireza.Kord
Dear All
Any solution for inserting Seismic Load Pattern with C (Base Shear Coefficient) and K (Building height exp.) in ROBOT like what exists in ETABS?
Replies (13)
Message 2 of 14
napooil
Message 3 of 14
Alireza.Kord
my problem is how to give C as User-defined base shear coefficient to robot
in the seismic code that im using, V as Building base shear calculated by V=C*W
what is C
C is base shear coefficient that is NOT accordance with ASCE (for this reason I cant use US Code ASCE 7-10 / IBC 2012 in robot) ,so I want to calculate C in the calculator for my building and just give the C to robot and then it obtains V from V=C*W and after calculting the base shear, it distributed over the height of the building in accordance with ASCE
is there any way to do this procedure in robot like what exist in etabs now?
Message 4 of 14
napooil
I think.In ARSP can not insert only k value same as your picture.
Message 5 of 14
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 6 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Dear Ak6,
Alternativly to the suggestion from mustafahesenow you may consider defining a combination with coefficient which would scale the bese shear to the expected value or use this option directly in the parameters ogf the seismic case
@mustafahesenow : thank you for helping
Artur Kosakowski
Message 7 of 14
napooil
Thank Mustafa Hesenow.I has concept for seismic force in my country code.
Message 8 of 14
Alireza.Kord
so is it true
if I set base shear on user value then robot does not consider s1, sd, ... parameters?
or in another word
when selecting user base shear ,changing S1, Ss, TL, Ie and Cd have no effect on analyse results?
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
They have as they determine displacements of a structure which corresponds to the distribution of forces but then the forces are scaled based on the base shear value you demanded.
Artur Kosakowski
Message 10 of 14
I hope this user defined seismic loading can be integrated withing RSAP's next realease. We need this since ASCE41-13
 has a different calculation of base shear than what is in ASCE7-10. Other softwares use the coefficient methods. The work arounds presented here are ok but it will be tedious unlike the coefficient method, because the coefficient is constant regardless of change in horizontal geometry of the bldg. Just what the TS stated, competitors have this.
Message 11 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not sure if I understand this correctly. If it is to scale the base shear to the targeted value it is already possible:
As you know W and C then it is W*C which you enter in the above field.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 12 of 14
@Artur.Kosakowski wrote:
Hi @Anonymous
Hello, like what i said, this option is not the same as the competitors. But i think this is acceptable. The user just have to know what is the seismic weight of the bldg, unlike the competitors where the inputs are Cs when you use the user defined seismic loading.
You can take a look at the snapshot of other contributors above. If RSAP can have this, i think it will stream line the user experience from one software to another, hence, potential RSAP users.
Message 13 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not an expert in this field however mixing parameters from a different code in the other one I'd personally found a bit confusing. The seismic weight of the structure is easy to see in the results of the modal analysis.
Artur Kosakowski
Message 14 of 14
The function you stated above is only available when you do dynamic modal analysis. It will not appear if you do only static analysis.
